Can't upload burst configuration files to PDM Link
I am currently starting a Arbortext pilot with our current PDMlink installation. We are running PDM Link 9.1 M060 and Arbortext 6.0 M040. It is a straight up installation and I am trying to upload default burst configuration files to a Library in PDM Link.
In Arbortext I can do the save as server object operation with no errors but the atidefaults.bcf never shows up in the library. I am able uploadsmaple dynamic docs no problem. PTC tech support is working on it but I just wondered if anyone else has encounted similar behaviour.
Stewart Maclean C.E.T.
Windchill Application Specialist
Information Technology
Weatherford | Edmonton Region
Cell: 780 905 0525
stewart.maclean@ca.weatherford.com | www.weatherford.com
    18-Opal
    May 4, 2012
    Hi Stewart--
    I think by default the atidefaults.bcf file doesn't appear in normal
    folder listings because it is a configuration file. I ran into this
    issue before, but I was able to locate the file by using the Search
    feature in the Object Browser dialog in Arbortext. Open the browser
    (Object->Browse...), select Search, and search for atidefaults.bcf.
    Hopefully it will appear there, and then you can check it out, edit it,
    or do whatever else you need to with it.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Clay,
    Thanks for the feedback. It did not work but I will bet that would have been the next hurdle.
    Stew
    18-Opal
    May 4, 2012
    Hi Stew--
    Another thing you can try is to connect to the repository in Arbortext,
    and on the command line type:
