Can you customise function keys
One of our illustrators has asked if I can put a macro to a function key so he doesn't have to keep picking the macro from a toolbar.
I can't find anything that says function keys can be set manually, so just hoping someone knows different.
    bfriesen
    18-Opal
    April 25, 2012
    In isodraw 7.2 m20
    Click on window, then toolbars, choose new, give it a name, then from the drop down box below it choose macros, you should now be able to slect them and add them to the toolbar. You will need to also choose what icon they will show up as on the toolbar.
    Hope this helps
    Bryon
    TimSharp1-VisitorAuthor
    Thanks, we do already use toolbars, but my colleague would prefer to be able to use function keys to run this macro - it's one that might be run scores of times on a drawing so he doesn't want to have to click the toolbar each time.
    I am not sure, but I dont think there is any option in Isodraw to set short cut keys.
    Wish one was able to customize a lot of the stuff on Isodraw....Make it more user friendly.
