Jul 2, 2015 10:24 AM UTC
Center lines missing while working with illustrations in IsoDraw 7.3
Recently i am facing problems with isodraw 7.3, when we are working on illustrations suddenly the center lines disappear. if i 'zoom in' or 'zoom out' the center lines appears and disappears. Graphics could be the problem? Help me solve this issue.
Aravind
aselvarajAnswer
Jul 13, 2015 5:56 PM UTC
Thanks Denise, we have solved the issue.
Try reducing the resolution of the screen.
It worked for me, i am not facing center line disappearing issues now.
Hope it will work for you too.
Aravind
Jul 6, 2015 12:42 PM UTC
I've seen the same problem and what seems to work is to view the drawing in "Preview" and save as a CGM. If you see the same problem in Preview, then do a "Select All" and see if the lines are there. You can also save the drawing as an EPS and see if that helps.
aselvaraj1-VisitorAuthorAnswer
Aravind
