Jan 8, 2015 3:28 PM UTC
cgm graphics
Hi adepters,
how to rotate some cgm graphics for pdf output in editor 6?
Thanks for your advices.
    Jan 9, 2015 12:37 AM UTC
    If you are using FOSI and if graphic entities are used in the document, the graphic can be suppressed and the graphic entity name can be fillvalled into a Putgraph category that has the desired rotation.Note that the graphic entity and notation do not have to be declared in the FOSI.
    For example:<e-i-c gi="graphic"><charlist inherit="1"></charlist><att><specval attname="print-only" attloc="system-var" attval="yes"><charsubset charsubsetref="SUPPRESS"></charsubset></att><att><specval attname="print-only" attloc="system-var" attval="yes"><fillval attname="entityref" fillcat="putgraph" fillchar="graphname"><charsubset><putgraph rotation="90"><subchars>...</subchars></putgraph></charsubset></att></e-i-c>Good luck!
    Suzanne Napoleonwww.FOSIexpert.com"WYSIWYG is last-century technology!"
    Jan 9, 2015 1:42 PM UTC
    I've tried it, but illustrations don't rotate. I don't know, where I've done mistake.
    <xs:element name="graphic" type="graphicElemType"/">
    <xs:element maxoccurs="unbounded" minoccurs="0" ref="hotspot"/">
    <xs:attribute ref="applicRefId"/">
    <usetext source="%}\DimenH=\ht\BoxA\vbox{\vskip\wd\BoxA\special{pub:rotate90}\unvbox\BoxA\vskip" -\dimenh}%&quot;placemnt="after"></usetext>
    Jan 9, 2015 10:38 PM UTC
    I assumed rotation would work because scaling works. But when I tried it now, the graphic did not rotate. That seems like a bug to me, and I would encourage you to report it.
    In the meantime, I found a way to make it work.In addition to setting the rotation characteristic on Putgraph, set scalefit to 1 and specify width as the column width. For example:
    <att><specval attname="print-only" attloc="system-var" attval="yes"/"><fillval attname="entityref" attloc="graphic" fillcat="putgraph"fillchar="graphname"/"><charsubset charsubsetref="SUPPRESS"><putgraph width="37pi" scalefit="1" rotation="180"></putgraph></charsubset></att>
    That worked for me in 6.0.
    Good luck!Suzanne
    Jan 12, 2015 7:07 AM UTC
    Thank you very much Suzanne.
    It's OK.
