Jul 29, 2019 3:08 PM UTC
cgm graphics published in raster
I use .cgm files created in isodraw. These graphics have vector elements with text.
When I publish the file which contain these cgm graphics, they appear in raster format and the text is also not searchable.
I find this problem with AE 6 and AE 7. This was not the case in AE 5.3, 5.4.
Any settings that I need to change?
Nim
bfriesen
18-Opal
Jul 29, 2019 3:14 PM UTC
Are you using editor for publishing and are you using APP. We found the same issue, we were using a fosi based style sheet at the time and there was a setting in editor that needed to be changed. See http://support.ptc.com/cs/help/arbortext_hc/ae61_hc/index.jspx?id=help17132&action=show
graphicapptransform should be set. Ours is cgm,idr,idrz,iso,isoz,svg:pdf.
Bryon
nim1121-VisitorAuthor
Jul 29, 2019 3:23 PM UTC
Yes I am using editor for publishing, and like you I use a fosi based stylesheet.
I modified graphicapptransform to cgm,idr,idrz,iso,isoz:eps since I think eps is the closest vector based format available (in the article cgm is not supported).
I tested it but I still don't see a difference.
Nim
bfriesen
18-Opal
Jul 29, 2019 3:29 PM UTC
Do you have access to styler. If so, open your fosi style sheet, click file, stylesheet properties, print/pdf tab. Change the print engine from fosi to APP. Try to publish again. The issue now is that you have a fosi stylesheet. We had to get ours modified to use APP.
Bryon
