Change color entities in macro
Hi everybody,
I'm stuck with this one...
I try create macro to select everything countaining color fill exept for the Black, White, and no fill, and apply to a pre define color called Shaded Area who is a black 45%. If somebody could help with that one it will be much appreciated!
Thanks a lot!!!
Macro Shaded Area
Add color "Shaded Area"
activeDoc.colors["Shaded Area"].kind = "CMYK_color"
activeDoc.colors["Shaded Area"].color.type = "cmykValues"
activeDoc.colors["Shaded Area"].color.CMYK = "{CMYK 0 0 0 0.45}"
Select if Color is not equal to '$ISO_NOFILL'
Subselect if Color is not equal to 'Black'
Subselect if Color is not equal to '$ISO_WHITE'
Color "Shaded Area"
Select none
End Macro
    Dutch_MnAnswer
    This may not be the best way, but it works
    Macro Shaded_Area
    Define i as Integer
    Define Count as Integer
    Define el as Element
    Add color "Shaded_Area"
    activeDoc.colors["Shaded_Area"].kind = "CMYK_color"
    activeDoc.colors["Shaded_Area"].color.type = "cmykValues"
    activeDoc.colors["Shaded_Area"].color.CMYK = "{CMYK 0 0 0 0.45}"
    Count = activeDoc.selectedElements
    el = activeDoc.firstSelectedElement
    Define myFill as Fill
    myFill.type = "color"
    myFill.colSpec.type = "colorRef"
    myFill.colSpec.color = "Shaded_Area"
    for i = 1 to Count
    el.fill = myFill
    el = el.nextSelectedElement
    End for
    Select none
    End Macro
    I've had a go at it myself, but can't find a way to change the color. When you use record macro, the resulting file is blank when at the bit where you change the color, making me think they've not put in an facility to change fill colours. Hope someone proves me wrong
    Dutch_Mn1-VisitorAnswer
    Macro Shaded_Area
    Define i as Integer
    for i = 1 to Count
    el.fill = myFill
    End for
    Select none
    End Macro
    Wow it work so well!!!
    Big thanks to you, it is much appreciated!!!!
