Character strings with no end-of-string asciicharacter
Easier, but then the rest of us wouldn't learn from it... 😄
Steve Thompson
+1(316)977-0515
    Andy,
    I'm not entirely certain which template string you should use for each
    of the cases you mention.  Which ones have you tried and what was the
    result?  As for the "unused byte", do you mean a byte of data that
    doesn't need to be written to the file, a byte in the file that
    doesn't come from any data in your application or some other meaning?
    I have never attempted to do anything like what you're doing.  My
    answers to your questions are based on reading the relevant
    documentation and experimenting.  Having given you some pointers in
    the right direction, I sincerely hope that you have done the same to
    the greatest extent possible, resorting to follow-up questions only
    when you have exhausted all of your own resources to resolve the
    problem.
    As noted by Steve and Ed, my email address is included with every
    message I send to the list, but I help others here as a way to give
    back to the community, from which I have also received help in the
    past.  I happen to make my living working for a company that stays in
    business, and pays me, largely from fees collected for private
    consulting work in this very field.  Unless I have written you
    privately or offered to help you with your problem off-list, you are
    presuming a commitment on my part to providing this same service to
    you for free.
    If you require private consulting, I'll be happy to put you in touch
    with our sales team.  We offer training, too. 🙂
    -Brandon 🙂
    On Tue, Aug 3, 2010 at 10:36 AM, Andy Leslie
    <info@structuredinformation.co.uk> wrote:
    > Hi Brendon,
    > I need to convert to Big Endian 16bit unsigned integer.
    > Is this pack("n*", buf) ? or should I use S* ? The value could be 64
    > I also need to convert to Big Endian 32bit unsigned integer.
    > Is this pack("N*",buf) ? Value could be 0, 1 or  2.
    > Furthermore, how do I specify an unused byte ?
    > Many Thanks,
    > What is your email address ? - be easier than working through the forum.
    > Many Thanks
    > Andy
