Nov 7, 2011 9:01 PM UTC
Check Completness in batch mode
Hi Everyone,
We are working in data modules using the S1000D specification, and using Arbortext Editor as our authoring tool. My question "Is there a way to do a check completeness on a group of data modules at once, or must we open each file individually to do a completeness check?
Sindy Young
AWACS Tools and Technology Team,
(253) 657-6964
Kent, WA 98032
    Nov 7, 2011 10:26 PM UTC
    Hi, Sindy...
    What kind of result would you be looking for, particularly in the case
    of modules that do not pass the check? Maybe just a plain text
    listing of the files with a pass/fail for each, or maybe just a list
    of those that didn't pass, so the user knows which ones to open up in
    Editor for closer inspection?
    If your requirements aren't too much more complicated than that, it
    should be relatively easy to construct a snippet of ACL to run on each
    file to invoke the completeness check and report the result in an
    appropriate form, which could then be run from the command line using
    the -b and -c (or -C1 or -C2, depending on your environment) options.
    -Brandon 🙂
    Nov 7, 2011 10:58 PM UTC
    Brandon,
    We are interested in getting a list of data modules that fail the completeness check.
    We have data modules in this structure:
    Data\xx\*.xml
    Data\yy\*.xml
    Data\zz\*.xml
    It will be great if the ACL can run the completeness check for all the xml files within the sub directories in the "Data" (as an example) folder.
    Any suggestions?
    Sindy
    Nov 8, 2011 12:07 AM UTC
    Are they spearated by doctype? procedures in one folder, ipb in another?
    If so you can use Kernow to just validate with the schema.
    ..dan
    > Brandon,
    > completeness check.
    > Data\xx\*.xml
    > Data\yy\*.xml
    > Data\zz\*.xml
    > Any suggestions?
    > Sindy
    Nov 8, 2011 1:07 AM UTC
    Something like the following might do what you need. You could put it
    in a file that you source before invoking the function, or just place
    the file in the "init" folder in your custom directory, so it's always
    available.
    The function takes a file name pattern (e.g., 'Data\??' to match items
    with two-character names). Directories matching the pattern are then
    searched for ".xml" files, each of which is checked and a list of
    those that couldn't be opened or failed the completeness check is
    returned.
    I've left the task of writing the resulting list to a file or to
    standard output as an exercise, since I don't know how you intend to
    invoke Editor to run this, or if you'll have something processing the
    result. Check back if you get stuck on that part.
    Caveat: I did test this, but then I reformatted, added comments and
    tweaked a bit, so no guarantees. 😉
    -Brandon 🙂
    function check_directories(pat){ local dirs[], files[], doc, i, j =
    0, s = ";
    # Make a list of items matching "pat" that are directories
    glob(pat, files); for (i in files) { if
    (file_directory(files[i])) { dirs[j++] = files[i]; } }
    # Search each directory for XML files and check each one for (i
    in dirs) { glob(dirs[i] . '\*.xml', files); for (j in
    files) { # 1024 = fail quietly if document type
    can't be loaded # 512 = do not load a stylesheet
    # 32 = suppress parser errors and warnings # 1 = open
    read-only doc = doc_open(files[j], 1024+512+32+1);
    if (doc < 0 || doc_incomplete(doc, 3)) { #
    Document couldn't be opened or failed completeness check
    s = s . files[j] . "\n"; } doc_close(doc);
    # Return list of files needing attention return s;}
