Jan 13, 2015 8:47 PM UTC
Check counter in styledesc?
Is there a way to check a page counter in the styledesc?
I'm trying to do this:
<specval attname="wpfolioct.txt" attloc="#FOSI" attval="#GT#\0\"> or
<specval attname="wpfolioct.txt" attloc="#FOSI" attval="#NONZERO">
but I'm getting a message that the content of wpfolioct.txt can't be retrieved.
    Jan 14, 2015 12:33 AM UTC
    Pagedesc variables and styldesc variables are mostly kept separate. Also, note that textids are evaluated as strings not numbers.
    You can test a counter in the pagedesc using a pseudo-element in the styldesc, and output gentext, for example. But you can't use the pseudo-element to change the value of a styldesc variable.
    e-i-c gi=psu
    And vice versa.
    What exactly are you trying to accomplish?
    cleccese1-VisitorAuthor
    Jan 14, 2015 2:26 AM UTC
    Hi Suzanne, I didn't want to change any values, just test whether the counter was >0 which would affect how I was building a string. But as it turned out I didn't need to check the counter anyway.
