May 14, 2014 3:43 PM UTC
check file saved as 7.2
Hi all,
I have Isodraw 7.3 but the client needs the files as 7.2, so there is a solution to check the files (if they are saved as IsoDraw 7.2) before I send them to the client?
May 19, 2014 7:23 AM UTC
Check for what?
mcardella1-VisitorAuthor
May 23, 2014 9:40 AM UTC
Hi Vladimir,
I saved the files with a macro but I am not sure that the files are saved as 7.2 correctly.
May 23, 2014 1:53 PM UTC
Unless that macro explicitedly calls out the 7.2 encoding it will save as the current version (7.3 in your case). As for checking the file before sending, I think you'd need to have another copy of IsoDraw (version 7.2) installed to confirm. I don't see anything in the file that could be parsed to check for version (I could have missed it).
If you manually save the file you can click on file type and you'll see that you can save back to an older version. You should be able to mimic that in your macro as well.
