checking element equality in javascript (rhino)
Hey everybody,
Let's say I do the following in Arbortext:
var document = Application.activeDocument;
var a = document.getElementById("stuff");
var b = document.getElementById("stuff");
So both a and b point to the same DOM element. Now, if I check their equality:
a == b
I get "false." Why is that? Shouldn't both variables contain references to the same object, and therefore be equal? Is there a simple way to check for element equality in javascript?
Note that when I do the same thing in a web browser, I get "true," like I expect.
James
    18-Opal
    January 12, 2011
    Hi James--
    Try a.equals(b).
    (FWIW, I think the behavior you're seeing is due to the way everything
    in Rhino is actually Java objects under the hood.)
    --Clay
    jsulak1-VisitorAuthor
    Thanks, Clay, that works perfectly.
    -James
