Mar 26, 2012 3:10 PM UTC
Clipping Mask for eps files
Hello: We are new to Arbortext and I'm wondering if it can recognize a clipping mask within an eps file. Example: If I have standards that say a graphic is restricted to a particular size and the author uses a clipping mask within illustrator to generate a portion of a larger picture,does Arbortext recognize that and only show the clip itself?
Tim
    Apr 1, 2012 11:52 PM UTC
    Hi Tim,
    I'm pretty sure this should "just work" - easiest way is to test it J Use
    one of the out-of-the-box samples from the New Document dialog, then insert
    the EPS graphic and print to PDF via PE or Styler.
    One thing to note - I'm also pretty sure that if you require text runaround
    of a clipping path (eg. non-square wrapping of text around an EPS graphic)
    then you would need to be using the APP print engine (which is the default
    in Arbortext 6.0 anyway).
    // Gareth Oakes
    // Chief Architect
    // GPSL (www.gpslsolutions.com)
