COM and Editor: openDocument with XML Schema?
I'm trying to open documents via COM in Arbortext Editor and supply Doctype and Stylesheet on the fly. This works fine for DTDs, but when I specifiy an XML Schema instead, the Editor fails to open the document. Do I miss something or is this simply not possbile with the Editor?
Call:
openDocument(pathToFile, 0x0040|0x0100, "", "", pathToXsdFile, pathToStylesheetFile);
Error:
Source: Epic.Application.1
Description: [A30295] Application.openDocument: Fehler beim Öffnen (something like "Error while opening")
Parser-Message:
pathToXsdFile : Line: 2 Column: 3
Expected a markup declaration
Line 2 of the XSD contains the following:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
Best regards,
Mathias
    MathiasH1-VisitorAuthor
    Ok, found it myself: The additional load flag OPEN_NAMESPACE_URI = 0x40000 must be specified and the public ID must be set to the schema URI.
