Mar 28, 2018 2:41 PM UTC
Command Line reference Editor, Editor with Style and PE
Greetings.
Currently using ArborText Editor with Styler 7.0. I looking to use Editor at a Windows CLI to publish documents into various formats. Right now, I am attempting to publish to PDF. The following is part of what I could put together (referenced from  - http://support.ptc.com/help/arbortext_hc/ae70_hc/en/#page/admin%2Fadmin%2Fhelp5717_help5717_1.html%23). I would like to know if my options are correct as I am not seeing a file generated.
editor -c -C1 stylesheet_select(<path to stylesheet>, <use>, <doc>)  <output file>
path to stylesheet  = windows path to stylesheet
use = 1 (which should be Publish to PDF)
doc = ???
output file = location of *.pdf
What options correspond to the input document (originating document that should be converted)?
What options should be specified for the output?
mastachef1-VisitorAuthor
Apr 27, 2018 12:29 PM UTC
Is there anyone out there who has done this?
