Jul 2, 2015 2:36 PM UTC
Composing SVG graphics through PE
I am working on setting up XML docs to compose SVG graphics through PE (5.4 M100, on Win2008 x64)).  Prior to this, we were using bi-level TIFF images.
I can get documents to publish with SVG images if it's just one or two per doc, but any more than that causes the "Java Heap Error".
Anyone have experience with this problem?  I tried setting APTJVMARGS to bump the java memory space, but PE started throwing errors about one of the built-in Windchill adapters no being able to create the JVM, so I backed that off.  Doing a set javavmargs or javamemory causes the same problem.
I had set graphicapptransform=svg:png; in the init directory, but that doesn't seem to help.
Short of upgrading to PE 6 to get an x64 build going (not a quick option for me), does anyone have any other recommendations?
