Jun 25, 2013 8:39 PM UTC
Context Rules turning on/off
Hello experts!!
I was wondering... there's a command in ACL which allows me to
automatically turn off the Context Rules Checking in Arbortext?
I really appreciate your response.
Paulette Zorrilla
    Jun 25, 2013 8:47 PM UTC
    here's a good trick to know:
    from the command line:
    response(menu_cmd("Tools.Context Rules"))
    This will display the command or alias that a menu item executes. For more
    details, look up "menu_cmd" in Help.
    Note: There are a few menu items in 6.0 that are "hidden" by some tricks
    PTC introduced behind the scenes. Edit>Delete Markup being one of them.
    Can't remember the trick to get around that right off the bat ...
    On Tue, Jun 25, 2013 at 1:39 PM, paulette zorrilla <
    paulette.zorrilla@oracle.com> wrote:
    > Hello experts!!
    > Regards.
    > Paulette Zorrilla
    Jun 25, 2013 8:49 PM UTC
    Ah, it's:
    response(menu_cmd("Edit.&Delete"))
    But I don't know how you would know what variable name they used in order
    to get around those menu items.
    pzorrilla1-VisitorAuthor
    Jun 25, 2013 10:11 PM UTC
    Paul! Thank you so much, as always you've help me a lot 😃 I will investigate now how can I execute the command received 😄
    Paulette Zorrilla
    Jun 28, 2013 7:38 AM UTC
    set context=off
    May 5, 2015 2:54 PM UTC
    Is there a way to "force" the user to run context checker before closing a document?
    May 5, 2015 3:13 PM UTC
    Have a look at the ACL command "doc_incomplete()". We have an ad-hoc document management system, and just check that prior to checkin, but I suppose you could do the same on document close.
    I will note/warn, however, that occasionally this does produce false-positives, so it might also be a good idea to check if the document is saved first, since that typically corrects things, especially when it comes to caret location.
    - keith
