Aug 9, 2011 3:32 PM UTC
Conversion from Visio to Isodraw
I have a set of Visio files that I need to import into Isodraw.
What is the best way to do that without losing information? (I tried exporting Visio to dwg and then to Isodraw but I lost some of the graphics on the way...)
Aug 9, 2011 4:15 PM UTC
Hello!
Which version of Arbortext IsoDraw and Microsoft Visio are you using?
P.S. Could you attach a sample file of MS Visio? Could you attach a sample file of MS Visio with whom you work?
kmi1-VisitorAuthor
Aug 9, 2011 4:29 PM UTC
Visio version is 2007
Isodraw version is IsoDraw 7.1 - Level F000
I will check if I can attach one of the Visio files - I am not sure I can do that at this point.
Aug 9, 2011 4:37 PM UTC
Well, if you can not attach a Visio file, try upgrade to the latest release IsoDraw 7.1 M060, here: https://www.ptc.com/appserver/auth/it/esd/index.jsp
P.S. Also in version MS Visio 2007, we can save only in the following vector formats: DWG, DXF, SVG.
