Sep 8, 2015 9:52 AM UTC
Conversion of 3D to 2D lineart (Technical illustration)
Currently I am working with Isodraw 7.1 version, my problem is when I try to convert 3D model (step format) to 2D line art, I see that the join are not perfectly joined and some miss match of lines.
Can any one suggest me to over come this issue.
Thanks!
Br. Illangovan
Sep 8, 2015 2:39 PM UTC
I am not aware of a fix as this was something we had dealt with as well.
I'll note that if your issue is applying fills you may want to look at upgrading. We're on 7.3 not and there is a function to apply a fill while in 3D mode that is translated when brought into 2D. Works pretty slick.
If you're stuck on 7.1 you'll likely have to keep going with the manual join approach.
