Jan 14, 2022 1:24 AM UTC
convert xml to PDF
I have so many languages xml file which needs to convert to PDF. Do you have any idea that how can I Create the same by using Arbortext editor.
@GI_317594 @si_01 @unknown
bfriesen
bfriesenAnswer
18-Opal
Jan 14, 2022 2:39 PM UTC
if you are only one user you could get a copy of styler and have the ability to publish with out publishing engine.
Bryon
Jan 14, 2022 2:34 AM UTC
Hello RK,
Basically, it require an Stylesheet to convert XML to PDF.
If your XML already comply with built-in Doctypes such as DITA, there are already stylesheets come with Arbortext Editor. You can use a print compose license in Arbortext Editor or Publish Engine to convert XML to PDF using the stylesheet.
If your XML comply with customized Doctype, you will need a stylesheet for it. In Arbortext, you can create stylesheet using 1) Styler. 2) XSLT/XSL-FO.3)FOSI.
Extra license for print compose and Publish Engine required.
Hope this helps
Jingjun
bfriesen
bfriesen18-OpalAnswer
18-Opal
Bryon
