Oct 28, 2011 6:34 AM UTC
Creating a Master DITA Glossary
Dumelang
Please would you kindly assist.
Client would like to:
- build a master DITA glossary with a handful of entries
- whenever he authors a new topic and uses a certain term for more than 3 times, that term should be flagged as a glossary entry in the current topic and then fetched from the master glossary and inserted into the map during assembly/publishing.
Is this possible? Any ideas would be greatly appreciated.
Kind regards
Tshediso
    Oct 28, 2011 8:37 AM UTC
    This would require some ACL/Java scripting, but looks doable.
