Apr 3, 2018 3:30 AM UTC
Creating new element in Stylesheet
I am attempting to create new elements in my stylesheet, I created them by copying another element that has the same base properties I need, giving it a new unique name, and then saving it.
After creating them, they do not appear in my style sheet list, I need to unselect the 'Only elements in document' and 'Only elements in document type' options from the View menu in the Styler.
The new elements I have created I put into my template xml file, but when I open the template, the tags for the new elements are red with a strike through, I can type any text into them, and parser messages appear for each tag with the following:
Error: unknown element in start tag. There is no such element as 'newelement'
How can I incorporate these new elements I have created into my stylesheet so they work with my documents?
Thanks.
Sean.
Apr 3, 2018 11:25 AM UTC
If only it were that easy! You're missing a piece of the puzzle. XML, in Arbortext, requires an associate DTD or Schema. This is the "document type" that the option you found in Styler refers to. The DTD/Schema defines the allowable elements and where they are allowed to be used. This is what lets Arbortext apply and keep a valid, known structure to the document, e.g. when you hit enter and it prompts for which element to insert.
The process to add new elements is therefore like this:
  1. Edit DTD/Schema file and add appropriate element/attribute definition(s) and update existing element definitions to list where the new element(s) are allowed to appear.
  2. Create a new sample XML with the new element(s) and make sure it validates in Arbortext. Fix DTD/Schema if not.
  3. Edit Arbortext .DCF file, if required, to indicate behaviour for the new element(s).
  4. Edit Arbortext stylesheet to add the definitions for the new element(s); adjust as suitable for screen vs print.
  5. If using Windchill bursting, and if the new element(s) are structural, make sure to update the burst configuration to account for the new element(s).
There are other auxiliary configuration items than the above (e.g. profiling), but my list should cover the main ones.
Apr 3, 2018 12:36 PM UTC
HI, I was going to write and tell you that you have to start at the beginning, from the DTD. Add the new elements and/or attributes to the DTD you are using, and then update the .dcf file if required. then when you go to Styler the elements will appear. Gareth has described it perfectly so follow his guidelines and you will be fine. This being XML everything starts with the DTD or Schema and builds down from there.
