Jun 10, 2016 8:56 AM UTC
CT attribute to accept or reject changes
We are required to have a solution to accept or reject changes for change tracking.
Is there a CT attibute that can be inserted in the begining of the xml file.
Example CT= ACCEPT -- should accept changes for atict:add
               CT=REJECT -- should reject changes for atict:reject
What kind of changes can be made in xslt sheet to process such kind of configuration?
Current XSLT sheet config:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0"
    xmlns:img="info.evccit.utils" extension-element-prefixes="img"
    xmlns:atict="http://www.arbortext.com/namespace/atict" exclude-result-prefixes="atict">
<!-- Change Tracking -->
    <xsl:template match="atict:chgm">
        <!-- Do nothing. Contains previous content of the markup -->
    </xsl:template>
    <xsl:template match="atict:*">
        <xsl:apply-templates/>
    </xsl:template>
    <xsl:template match="atict:add//text()">
        <xsl:element name="ADD">
            <xsl:value-of select="."/>
        </xsl:element>
    </xsl:template>
    <xsl:template match="atict:del//text()">
        <xsl:element name="DEL">
        </xsl:element>
    </xsl:template>
    <!-- Change tracking for headers -->
    <xsl:template
        match="TECHNAME/atict:del | DMREF/atict:del | INFONAME/atict:del | atict:del//NOEQUIP"> </xsl:template>
    <xsl:template match="TECHNAME/atict:add | DMREF/atict:add | INFONAME/atict:add">
    </xsl:template>
    <!-- Change tracking for links -->
    <xsl:template match="atict:del//XREFEXT | atict:del//XREF">
            <xsl:element name="{local-name()}">
                <xsl:apply-templates select="@*"/>
            </xsl:element>
        </xsl:element>
    </xsl:template>
Could you please help?
Thanks.
