Nov 15, 2010 8:29 AM UTC
cursor info highlighting problem
Good day all,
We've installed Arbortext isodraw 7.1 recently. While working in it we are not able to highlight the CURSOR INFO in the botom left of the drawing screen.
because of that we are not able to work efficiently in isodraw. We've tried in the edit-preferences and highlighted the cursor info settings also. but, still it has problem. Kindly check it and advise.
Thanks for your cooperation in advance.
-Velu
    Nov 15, 2010 11:05 AM UTC
    Hi, it only works, when you have activated all these checkboxes:
    Cursor info is only active when "Draw elements in background" has been selected on the "Redraw" preferences page.
    http://www.balko.macbay.de/Austausch/IsoDraw/Cursor-Info3.jpg
    Aug 10, 2011 5:27 AM UTC
    Cursor information is available only if the preferences page "Redraw" selected "Use buffered drawing" ("Edit" => "Preferences" => "Redraw" => "Use buffered drawing").
