Dec 16, 2022 8:26 AM UTC
Customization to stylesheet to post process the intermittently generated PDF
We are able to generate the PDF file from Arbor text editor with Publish->PDF option using XSLT stylesheet. Intermittently PDF has to be generated and modify the content before generating the final PDF. Could you suggest what ways customization can be done in XSLT to achieve the required functionality.
Thanks in advance.
