May 1, 2015 4:01 PM UTC
Customized Menu Removed after Initiating the "set stylesheet=" command
Arbortext Editor 5.4 M110
Background:
  • Menu customization is implemented using ACL and loaded at runtime from the [editor root]\custom\editinit\ folder.
  • The menus are not visible unless a document with the designated doctype is opened.
  • I am new to Arbortext Editor development.
Context:
  • Attempting to write ACL service that will allow content authors to change the FOSI style sheet form the current document "edit" window.
  • Using the ACL command "set stylesheet=fosiname.fos"
Issue:
When the "set stylesheet" command it initiated, the custom menus are removed.
Any idea what is happening? Or what I need to do to reload the menus?
Thank you in advance
May 4, 2015 1:43 PM UTC
Have you reviewed the menuloadhook?
May 4, 2015 1:51 PM UTC
Here is an example;
package testmenuhook
function testmenuhook_addmenus(win=0,filename="")
# add some menus to the Tools button
if (menu_exists('.Tools') && !menu_exists('.Tools.Export_XML'))
menu_add .Tools. "" -separator
menu_add .Tools. "Export XML" -cmd {eval "here's export_xml"}
menu_add .Tools. "Import XML" -cmd {eval "here's import_xml"}
May 4, 2015 1:58 PM UTC
missed the last 3 lines resubmitting.
Here is an example;
#set up menus
add_hook("menuloadhook","testmenuhook::testmenuhook_addmenus")
testmenuhook_addmenus()
May 4, 2015 2:30 PM UTC
Hi Tim,
First let me thank you for responding to my question. Now to answer your question.
Not sure what you mean by;
>"Have you reviewed the menuloadhook?"
Background:
The custom menus established with the "menu_add" method and with the "add_hook" method is currently in the ACL stored in location "[editor root]\custom\editinit\" and is loaded at startup. I am writing a different tool that is also stored in this ACL file that allows the end-user to change the FOSI style sheet using the "set stylesheet=" command. When this command is submitted, the custom menus established with the "menu_add" method and with the "add_hook" method are removed.
Questions:
  1. Are you suggesting I need to reload the menus with the "menu_add" method and "add_hook" method after submitting the "set stylesheet=" command?
  2. Is this common practice?
  3. Is there a way to reload the ACL in the "[editor root]\custom\editinit\" folder?
