Daily WTF
Can anyone help this guy out with his PE bug? 🙂
    Richard!
    crashtrain
    John Sillari
    Chief Technologist
    Dayton T. Brown, Inc.
    He needs a kick!
    ...in the crash!
    No joke. I've had this error occur on our PE servers. It's painful.
    John Sillari
    Chief Technologist
    ERROR IS: Cannot find file called markitx. Is it in the currently active directory
    (err:1 line:1 pos:856)
    Compile failed - rc=32
    I can't determine which directory is should be in or where to get it from.
    Any documentation would help.
    Annie Hartley
    The Boeing Company
    GSS-IT
    Markit is the parser that Arbortext Editor uses to validate documents. The inability of Arbortext Editor to find Arbortext-native files often occurs when you use an APTCATPATH environment variable that does not contain %D as one of the paths. (%D is the default path to Arbortext's own catalog files.) Your APTCATPATH variable value should read something like: C:\mydocuments\mydoctype;%D Leaving out the %D (don't forget the semi-colon separating it from the previous path) would cause this.
    Thank you Ed. I will try to modify this path.
    Annie
    FYI - That is literally "%D" (without the quotation marks).
    Hi Annie -
    We also had the markitx issue when we first started with ArborText. Our
    fix was to give the user full permissions to the "C:\temp" folder which AT
    was using. Apparently, markitx is associated to one of the temp files AT
    creates and then reads and then deletes. When the user did not have Read
    and Write permissions, AT would return the error you mentioned.
    Hope this helps!
    Thank you,
    Matt Angel
    Technical Publications Engineer
    ZODIAC BIZJET INSERTS
    GALLEYS & EQUIPMENT
    44931 Falcon Place - Sterling - VA - 20166 - USA
    Thank you Angel for this information.
    Annie Hartley
    The Boeing Company
    GSS-IT
