Sep 29, 2015 2:17 AM UTC
Data marked not to be published or not published due to filter.
Dear PTC Arbortext Experts
When I tried to publish a dynamic document from my Arbortext content mannager the words
"ATTENTION! Data marked not to be published or not published due to filter. No publishing will take place."
came up.
All that I have done to this point is
1. create a book using the template sample for doc book
2. save it a dynamic document on the content manager.
3. try to send it to publish
If anyone can help I would like to know what and when this filter or mark was set, and how i can remove it.
Thank you for all your help
rdiazAnswer
Sep 30, 2015 6:56 PM UTC
Hi Ninomiya,
It sounds as if maybe you do not have a Publishing Rule for this document type.  You need to configure the publishing rules for the document type, and you can refer to Windchill Visualization Services Guide to get the information about configuring publishing rule.
Hope this helps!
rdiaz5-Regular MemberAnswer
Hi Ninomiya,
Hope this helps!
nyasunobu1-VisitorAuthor
Oct 2, 2015 8:32 AM UTC
Thank you for your help Mr Rafael
I got passed the Error, and was able to advance to the publication process.
Nov 16, 2015 2:50 PM UTC
Ninomiya,
Could you elaborate on how you resolved the issue?
It would be helpful to the community to know the resolution, so that anyone experiencing the same issue, will know how to resolve it.
Thanks!
