Apr 6, 2016 2:20 PM UTC
Debug Message window
I am using Arbortext 7.0 F000 and obtaining the annoying Debug Message window every time I paste jpeg graphics into my document.
I have been using Arbortext 7.0 for over three months now and this started happening on the morning of 4 April 2016. I work offline. The error in the Debug Message window reads "add_psv: Cannot insert page reference due to invalid saveref". I see no saveref preference or value in advanced Preferences.
I set the pastesource preference to blank "fix" reported in the post by Steven Powell Apr 29, 2014 12:10 PM, however this did not work.
Any recommendations?
Apr 14, 2016 1:48 PM UTC
Thanks to Brent Kelly for resolving this case. The reason:
The issue is caused by your FOSI. The problem is that:
• Arbortext's FOSI implementation does not allow for time-dependent variables that are modified in the pagedesc to be modified during flowtext processing.
• The FOSI engine warns users about illegal use of time-dependent variables".
Unfortunately the document is not written by one person (me) who is familiar with DTDs and FOSIs. I will have to repair the XML tags in the document before this Debug Message disappears.
Apr 8, 2016 1:34 PM UTC
As of 4/08/2016 the Debug Messages window appears when (1) inserting new illustrations and (2) refreshing my document.
Apr 8, 2016 7:31 PM UTC
Hi Michael,
I suggests that you upgrade to AE 7.0 M020. BR/John
Apr 11, 2016 2:37 PM UTC
Thanks John,
It seems as if I have M040 installed already. Here are the version on my computer:
Version 7.0.F000
Build number R70F000-1188
Technical Information Application 6.1 M040 (Build R70F000-1122)
do you or some other user know if there is a Major, patch, or Maintenance release available?
Thank you, Mike
mleboulluec1-VisitorAuthorAnswer
