May 17, 2017 3:21 PM UTC
Did the Find Attribute feature get removed from 5.4?
In the previous version, I was able to search for tags with specific IDs. For example, I could search for an xref with xrefid "ABC".  In 5.4 I can't find that feature anymore.  It use to be under the Find tool in the menu bar.  Did this feature get removed, or do I have to configure a certain setting or preference?
May 17, 2017 4:53 PM UTC
One more thing, make sure that in your tools/preferences/windows menu you have full menus clicked on. Else you will not see the tags for find that you are looking for.
May 17, 2017 4:39 PM UTC
Hi, I just opened 5.4 m100 and the find tag/attribute/value was there in the find pull-down and it worked as advertised. I have no scripts or ACL running that would make a difference.
What version of 5.4 are you running?
Ray
fcalderon1-VisitorAuthor
May 17, 2017 4:43 PM UTC
Find menu.jpgHi Ray,
I'm running M030.  Previously I was running 5.3, but we moved on to 5.4 when we finally switched over to Windows 7.
