disable hyphenation APP
Hi all,
I have the following question.
We are using arbortext 5.4 m130.
could be posible in app stylesheet disable the option of hyphenation.
we don´t want to cut any words in the document, we need that all the words go to the next line.
thanks in advance and regards,
Ramón
bfriesen
bfriesenAnswer
18-Opal
August 17, 2012
I had the same issue in editor 6. This is what I did with the help of PTC tech support
Open editor with styler
Open a ditamap
Click so your cursor is just below the servicemanualmap element at the top of the ditamap. ( I Would expect this will change with whatever style of topic you open i.e. procedure, task, concept, etc..)
On the tool bar click styler, edit stylesheet.
Check that you are on the elements tab, and that servicemanualmap ( I Would expect this will change with whatever style of topic you open i.e. procedure, task, concept, etc..) is selected and green. (Green refers that it is the top element)
Choose breaks, under print/pdf and RTF only, find word breaking and set to Do not break.
Bryon
bfriesen
bfriesen18-OpalAnswer
18-Opal
August 17, 2012
Open a ditamap
Bryon
