Display generated text in TOC
Hi everybody!
Is there a way to display generated text in TOC?
When I select a element with a generated text (Usually the chapter number), the TOC shows only the element's text and not the generated text.
TimPhelpsAnswer
From Styler on the Table of Contents tab with the specific TOC selected does selecting the Format button and then from there the Details button is the "Numbered" radio button checked?
If you are using Arbortext Styler, then select the Gentext Tab, then the Number radio button and then the Details button.
In the Number Details dialog one can add a previous number level for a selected element.
One can add a label or select "Advanced Edit" button for a more complex label.
rboneti1-VisitorAuthor
Tim,
This is ok. Which I really need is that this generated number appears in Table of Contents. This configuration shows the numbers only in the element where I've done it, but not in the Table of Contents.
TimPhelps12-AmethystAnswer
