Apr 29, 2011 10:52 AM UTC
display of full _pi´s
is there a way to display the full value of an processing instruction. Were using processing instructions with many attributes and the arbortext editor prior 5.2 is displaying the full tag, but the newer versions cut them off and puts three points at the end. I have currently now clue how to activate this in some way?
thanks in advance for any ideas
Andreas
    May 10, 2011 11:36 AM UTC
    Andreas
    The limitation doesn't seem to be applied to tags as you mentioned (checked in both 5.4 and 6.0). See the screenshot below
    Apr 29, 2011 11:02 AM UTC
    Andreas, can you provide a sample .xml, a screenshot with the current view and a screenshot with the desired view (from 5.2)?
    Also, which version you're on now?
    Apr 29, 2011 11:18 AM UTC
    Dmitry, attached you´ll find the files with the pi´s. Before Arbortext editor 5.2 (5.1,5.0, 4.x) and from version 5.2 and above.
    thanks
    May 10, 2011 11:04 AM UTC
    This restriction is set from PTC since version 5.2. All tags and pi´s are restricted to the length of 128 signs. This is hard coded, so currently nothing can be changed on this problem. A solution might an improvement from PTC.
