dlgitem_set() and subsequent queries of set controls?
I am updating a checkbox in a XUI document in Editor 6.0 m010:
dlgitem_set($win, 'mycheckbox', 'VALUE', 1)
The dialog visually updates as expected 100% of the time.
Subsequent tests of that checkbox's state SOMEtimes report that it is
unchecked.
Has anyone seen behavior like this?
Paul Nagai
    18-Opal
    July 5, 2012
    Hi Paul--
    I haven't seen it before, but one thought I had was to check whether you
    see any difference between using dlgitem_get() and dlgitem_get_value().
    Whichever one you're using now, maybe try the other and see if you get
    more reliable results.
    You might also try varying between dlgitem_set() and dlgitem_set_value()
    to see if that makes any difference.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
