DMP Consumer 6.0 m010 ApplicationContextFacade error:
When I perform a search (simple or advanced) the search results are:
The page you requested contains an error and cannot be displayed.
Error Status: 500
Unable to find a value for "contextPath" in object of class
"org.apache.catalina.core.
ApplicationContextFacade" using operator "."
Has anyone seen and fix this yet? Oh. Hmmm. Just realized: Tomcat 5.0.18.
Wonder if that's too old for DMP/C 6.0?
Paul Nagai
    18-Opal
    February 9, 2012
    Hi Paul--
    I haven't tested it, but from the specs, it looks like your hypothesis
    is probably on target.
    The DMP Dev Guide for 6.0 says: "the WAR file can be deployed in any
    servlet container, application server, or web server supporting the JSP
    2.0 and Servlet 2.4 standards". According to
    naglists1-VisitorAuthor
    Am now fighting with different DMP Consumer errors using the DMP
    default/demo project (so not one of my moderately customized for 5.4 mXXXX
    "upgraded/migrated" to 6.0). Sigh. This with a new or near new Tomcat/Java
    environment. For what it's worth, the standalone DMP Consumer module does
    load and search OK so this confirms Clay's confirm of my assume.
    (My customized projects do not load, however, so clearly I've got some mods
    to un-mod or re-mod for the 6.0 environment.)
    Anyhow, I get three different results when attempting to load the web
    application via Tomcat. On the first attempt:
    javax.servlet.ServletException: Error instantiating servlet class
    com.arbortext.dmc.consumer.index_jspx
    org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
    org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
    org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
    org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
    java.lang.Thread.run(Unknown Source)
    root cause
    java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
    org.apache.jasper.runtime.HttpJspBase.<clinit>(HttpJspBase.java:43)
    sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
    sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown
    Source)
    java.lang.reflect.Constructor.newInstance(Unknown Source)
    java.lang.Class.newInstance0(Unknown Source)
    java.lang.Class.newInstance(Unknown Source)
    root cause
    java.lang.ClassNotFoundException: org.apache.commons.logging.LogFactory
    org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
    org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
    Source)
    note The full stack trace of the root cause is available in the Apache
    Tomcat/6.0.35 logs.
    18-Opal
    February 10, 2012
    Hi Paul--
    Check that the Apache Commons Logging library is available to Tomcat.
    See this page:
    Clay, FTW!
    Duh.
