Apr 15, 2014 8:37 AM UTC
DOCTYPE & Element attributes - Save As Preferences
Hi Chaps,
When saving an XML, the !DOCTYPE and also some element attributes are removed.
Is there a setting in Preferences > Advanced, to stop this occuring?
Thanks in advance,
Samuel
    Apr 16, 2014 11:57 PM UTC
    This doesn't happen here. I opened your sample XML in Free Form mode, without DTD, and did a Save As. The only differences are:
    1. the Arbortext comment
    2. single quotes turned to double quotes
    3. placement of a <?Pub Caret -2?> PI at end of document (marking where my cursor was when I saved)
    I tested on Arbortext 6.0 as I don't have 6.1 handy.
    Apr 16, 2014 12:55 AM UTC
    This should not happen, can you describe the steps which reproduce this behaviour?
    Apr 16, 2014 7:31 AM UTC
    Didn't think so, OK...here it goes...
    Open File 1:
    <?xml version='1.0' encoding='utf-8'?>
    <!DOCTYPE planungsanleitung PUBLIC '-//Client//DTD DocumentType//DE' '/system/dtd/planungsanleitung/planungsanleitung.dtd'>
    <planungsanleitung y.io.id="daf88359619038f0ac140e0e4de97dc5" y.io.version="6" y.io.variant="GB" y.io.language="en" y.io.format="ClientDocPAXML" y.io.owner="ksi" y.io.status="Approved" y.io.name="5368768" y.io.revision="8">
    <meta>
    </meta>
    </planungsanleitung>
    No validation error.
    Save As Result: all attributes are removed from planungsleitung element and copied to meta....and "?" are added to the DOCTYPE root element:
    <?xml version="1.0" encoding="UTF-8"?><!--Arbortext, Inc., 1988-2013, v.4002--><?DOCTYPE planungsanleitung PUBLIC "-//Client//DTD DocumentType//DE" "/system/dtd/planungsanleitung/planungsanleitung.dtd"?><planungsanleitung><meta y.io.format="ViessDocPAXML" y.io.id="daf88359619038f0ac140e0e4de97dc5" y.io.language="en" y.io.name="5368768" y.io.owner="ksi" y.io.revision="8" y.io.status="Approved" y.io.variant="GB" y.io.version="6"></meta></planungsanleitung><?Pub?>
    Any ideas?
    Thanks in advance.
    Apr 16, 2014 1:01 PM UTC
    Have you checked for any callbacks or save hooks in your custom folders? The functionality doesn't look out of the box for Arbortext.
    You can check in the /init or /scripts directories under your custom folders.
    -Jeff
