Feb 16, 2017 4:42 PM UTC
Does anyone have a custom macro to remove object tip information from objects?
Hi there,
we have a bunch of 2d and 3d graphics that have "object tips" in the Objects.  We only need to remove the object tip (the hovering text) part.
Is there an existing custom macro for that or is there a batch process technique?   I would like to streamline the process for efficiency.
Any ideas?
kr
Janine
Feb 16, 2017 5:42 PM UTC
Made an assumption. Please correct if wrong. You can't actually delete 'object tips' as it is a built-in field (well, technically you could by some in-depth customizations but I digress). So I'm assuming you just want the value set to null for this field. The following macro should do this. Not it does this at the top level. What I mean is that if you have a group with an object tip it will clear that. But if you have additional object tips within that grouping it does not go that far. Possible, but it gets much more complicated.
Macro Remove_Object_Tips
    #Declare variables
    Define el as Element
    #Clear existing selection.
    Select None
    #Select all objects with object tips populated.
    Select if Object_tip is not equal to ""
    #Loops through objects removing object tips.
    el = ActiveDoc.firstSelectedElement
    While(exists(el) = True)
        el.info.tip = ""
        el = el.NextSibling
    End While
    #Clears selection.
        Select None
End Macro
Feb 16, 2017 6:39 PM UTC
Thanks Trevor, but it didnt work for 3D embedded Object information tips that are embedded...any other ideas?
Thanks so much, Janine Hasselbring
Feb 16, 2017 6:40 PM UTC
It did work great for the 2D object tip removal though
