bfriesen
18-Opal
Jul 24, 2018 3:29 PM UTC
Duplicate callout in svg when publishing with Arbortext Publishing Engine
We are exploring switching from CGM to svg to reduce publishing time, but we have come up with an issue. We are just finishing setting up Arbortext publishing engine 7.1 m020 and it seems that Ape duplicates the callouts. See case CS284369. The work around is to modify the svg. We have 25,000 or so images that I have converted in Isodraw to SVG that would need to be modified. What are others doing for there work flow around this issue.
 It does not seem to have any sort of priority to get fixed as the case is for 7.0.
Bryon
bfriesen
bfriesenAnswer
18-Opal
Aug 28, 2018 2:00 PM UTC
This is fixed in 7.1 m021.
Bryon
bfriesen
bfriesen18-OpalAuthorAnswer
18-Opal
Bryon
Jan 9, 2020 4:02 PM UTC
Bryon,
I have 200,000 isodraw graphics that i currently help curate. Thank you for the insight.
