bfriesen
18-Opal
October 29, 2013
dxf import into IsoDraw
We are moving to importing dxf files into Isodraw for line drawings. Is there a way that I can specify that a text layer in the dxf gets imported onto a layer labeled text in my IsoDraw template? or does this need to be done via a macro after the dxf has been placed in the file?
Bryon
Hi, the only (and best) way what I know is to do that with a macro ...
bfriesen
bfriesen18-OpalAuthor
18-Opal
November 6, 2013
So you place the dxf, then run a macro against it to create the layers and move the different items onto them?
Bryon
I do not do that because I don not need it ... but I would do it this way if needed ...
