Edit Selection as XML Source in 5.3M130
We were using AT 5.3M010 which had bug issue and so now we have 5.3 M130. I don't see "Edit Selection as XML source" in this version of AT.
Karthik
    18-Opal
    March 12, 2010
    Hi Karthik-
    Make sure you have "Full menus" enabled in your preferences. I think
    this is off by default.
    --Clay
    We're only at 5.3 m110 but we still have it. Is this possibly a fullmenus
    thing? Issue "set fullmenus=on" on the command line and try again.
    On Fri, Mar 12, 2010 at 12:15 PM, Karthik Kumar <
    karthik.kumar@merrillcorp.com> wrote:
    > Hello,
    > Karthik
    How can I forget the basics?!?!?! Too bad. Thanks Clay. It works now.
    On Fri, Mar 12, 2010 at 12:55 PM, Karthik Kumar <
    I got bit by the "is it plugged in" question just the other day. No,
    literally, it wasn't plugged in. Ah well ...
    Paul Nagai
    When I was a calibration technician in the Air Force, we would sometimes get trouble calls about electronic equipment. More than once we asked the question: "Is the O-N O-F-F switch in the O-N position?" The answer would frequently be, "Ohhh...no...heh heh..."
