Jul 25, 2017 8:13 PM UTC
Editing graphics that are in Windchill
I'm having trouble editing graphics that that are referenced in a DITA topic:
  • If I'm editing a topic that is saved locally, double-clicking a graphic opens it in my laptop's default program as expected.
  • However, if I view (or check out and edit) a topic that is in Windchill, I get the following warning:
Is there something I need to set up on the server side, in my DTD, or in a local environment variable?
Aug 22, 2017 5:32 PM UTC
If you have a DITA topic that references a Creo/Illustrate graphic which is stored in Windchill, then you can double-click in Editor to launch Creo/Illustrate.  Note that this can be a .c3di source or a .pvz.  If it is a .pvz, then Editor will locate the associated source in Windchill and open it in Creo/Illustrate.
This was added in 7.0 M030.
We have not yet added this support for other graphic types.
Apr 25, 2018 1:33 PM UTC
We are also having this issue.  Is PTC going to add the function back for other Image Editors?  Like Adobe Illustrator?
