Editor and java 7
I know it's not officially supported, but is anyone using java 7 with
Editor or PE 6.0? If so have you experienced any problems?
Brian Jensen
bjensen@bluelid.com
    I am currently running a workstation with the following environment:
    Windows 7 Ultimate (64-bit) on an Intel Core i7 processor
    Java 7 update 5 (64-bit)
    Arbortext Editor with Styler 6.0 M040 (64-bit)
    As far as I can tell, I am not having any issues specifically related to Java, but your mileage may vary...
    BrianJ1-VisitorAuthor
    Hi Eric,
    Thanks for your response. Our client was hoping to move to java 7 update
    9, but when I tried running Editor with the jvm set to this latest java
    version I got segment 11 errors popping up on startup about half the
    time. We have quite a bit of customization written in java, so I'm
    guessing it's some problem between our java code (we're using java 6
    update 34 now) and java 7. We explained the deadly nature of segment 11
    errors and they quickly decided they were OK with our current setup 🙂
    Brian Jensen
    bjensen@bluelid.com
