bfriesen
18-Opal
May 30, 2024 12:34 PM UTC
Editor/PE/Styler 8.2.3.0 is released
Download found here: https://support.ptc.com/appserver/auth/it/esd/index.jsp
Editor
SPR Fix Description
14935691 Revise button is not getting enabled for newly uploaded
document.
15037678 '[A30282] Invalid XPath expression: The prefix 'x3b2' is
not declared' error when opening xml file.
15103751 Arbortext Editor - UWGM logs are enabled by default.
15106317 Issue with Export Compound Document when there is a
character entity in a graphic path.
15138933 Inserting a very large amount of text into a buffer causes
Editor to crash.
14679064 ISOCONVERT: Isoconvert graphic conversion run from
Arbortext Publishing Engine causing callouts to lose
aligment with rest of graphic.
15182701 Users are unable to edit SGML documents. Attempting
to insert elements using the insert markup panel causes
Editor to crash and exit.
15185920 Print Composer directories not being installed when
selected from the Custom Setup dialog.
15262881 When performing a change on a checked out DITA
concept and a FILE ▶ SAVE, the plus (+) sign no longer
appears next to the check out icon prior to the concept
tag.
PE
SPR Fix Description
Fixed the issue with compressed pdf publishing (no spr listed)
15024880 Alpha headings for indexes is not displaying for the
Portuguese language in Arbortext Styler and Publishing
Engine
15037927 After updating Arbortext Publishing Engine 8.2.0.0, all
users can delete any jobs in the Queued Transactions
dialog box
15107387 Sending emails for queued transactions fail with
"MailcapRegistryProvider runtime exception" in
15133583 Publishing from Windchill is not including graphics that
are referenced as entities.
15201900 When using transaction archive and Queue list from PE
Test page (http://localhost:8080/e3/) receive error
Arbortext Publishing Engine.
15251988 Cross References(xref) are not working for a Dita
document
Styler
SPR Fix Description
14931766 Arbortext Editor should not attempt to process conrefs if
no conref defined attribute is in the DTD.
14980580 Switching language in Gentext editor in Styler changes
'Translate based on content' option to 'Do Not Translate'
15026896 Publishing to Postscript using some PDF pages as graphics
and graphics do not appear in Postscript output
15239979 ACL function open_connect() can cause Editor to crash
15385925 Unable to use Mongolian indexing in Styler and ALD
15428548 Hang or crash when removing target language from
modular stylesheet
olivierlp
Community Manager
May 30, 2024 2:00 PM UTC
Hi @bfriesen and thanks for posting this update!
Olivier
Jun 4, 2024 1:23 PM UTC
Arbortext 8.2.3.0 and Arbortext Layout Developer 12.2.3.0 were released May 30, 2024
These were maintenance releases primarily containing customer bug fixes as detailed above. (Thanks, Bryon)
The version of Creo View was updated to 10.1
The list of ALD/ALE bug fixes is:
14981351 ruleAll breaking block
15116229 Unexpected mapping with a wrong Char and ALD crashes after a format.
15118010 Wrong PDF tagging structure when there are footnotes on the page.
15134415 Pretty print and normalisation issue where characters are changed.
15223714  tspref" setting not saving Language value
