Enable/disable XUI Button
Hello experts, amateurs and everybody!! 😃
I have been investigating about how to enable or disable an XUI button.
I was thinking that maybe this is possible using the dlgitem_set()
command, however I'm not pretty sure how to do it 😞 Does anybody know
more about this area? Thank you so much in advance.
Paulette Zorrilla
    Assuming the button will always display but be active or inactive based on
    some logic, I use:
    dlgitem_activate($win, $button_id)
    dlgitem_deactivate($win, $button_id)
    If showing and/or hiding the button entirely is your goal, that's
    different. My code above will "gray" the button when it is deactivated and
    make it non-user-selectable.
    On Tue, Aug 20, 2013 at 2:22 PM, paulette zorrilla <
    > Paulette Zorrilla
    pzorrilla1-VisitorAuthor
    Paul, thank you so much. It works! What I was needing is was only to enable or diable the button.
    Paulette Zorrilla
