Jan 5, 2012 8:55 PM UTC
Encrypted PDFs
Adepters:
We're using PE 5.3 Patch M190 to generate direct-to-PDF output. We have a requirement to deliver secure PDFs - you can open and read, but cannot save or copy/paste. Does anyone know if Arbortext supports this in any version of PE. If not, can someone recommend a third-party batch tool that could be inserted in the process to secure a PDF.
Dave Hintz
    18-Opal
    Jan 5, 2012 9:00 PM UTC
    Hi Dave--
    I'm not sure about 5.3, but I know in 5.4 you can control these options
    by setting up a custom PDF config file. I don't have a copy of 5.3
    handy, so I'm afraid you'll have to check for yourself if these options
    are available there as well. See the extensive comments in the pdfconfig
    DTD file (found in $EDITOR/doctypes/pdfconfig/pdfconfig.dtd) for details
    on how to set attributes to control the various security settings.
    Here's a snippet from the 5.4 version:
    Acrobat allows certain features to be restricted in its UI. The
    features that can be disabled are:
    * noprint: Acrobat will prevent printing the file.
    * nomodify: Acrobat will prevent users from adding form
    fields or making any other changes.
    * nocopy: Acrobat will prevent copying and extracting
    text or graphics, and will disable the
    accessibility interface
    * noannots: Acrobat will prevent adding or changing
    comments or form fields.
    * noforms: Acrobat will prevent form field filling, even
    if noannots has not been specified.
    * noaccessible: Acrobat will prevent extracting text or
    graphics for accessibility purposes (such as a
    screenreader program)
    * noassemble: Acrobat will prevent inserting, deleting, or
    rotating pages and creating bookmarks and
    thumbnails, even if nomodify has not been
    specified.
    * nohiresprint: Acrobat will prevent high-resolution printing.
    If noprint has not been specified printing is
    restricted to the 'print as image' feature
    which prints a low-resolution rendition of
    the page.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Jan 5, 2012 9:08 PM UTC
    Thanks, Clay! We've been putting off upgrading to 5.4, so this might be a good reason.
