Dec 29, 2017 3:25 PM UTC
Environment Variable - SYSTEM vs USER
Are there any impacts on Arbortext Editor 7.0 with Print Composer when composing xsl-fo to PDF if the environment variables are setup as USER environment variables and the software was installed by administrator?
Having issues getting the following to work:
<fo:external-graphic src="url({$slash2})" />
The value inside the url() does resolve correctly.
