EPIC 4.3 PRB FOSI ID/REFID
I have problem when i use ID/REFID
<!-- XML File -->
<table id="tbl-4">
</table>
<para> cccccccccccccccccccccccccc
<obj refid="tbl-4">vvvvvvvvv</obj>
</para>
<!-- TREAT ID -->
<e-i-c gi="table">
<charlist inherit="1" charsubsetref="espvtitre">
<indent inherit="0" leftind="@" firstln="*">
<quadding quad="center">
<textbrk endln="0">
<enumerat increm="1" enumid="tabct">
<savetext textid="tabctxt" conrule="tabct">
<savetext textid="tabnum" conrule="tabctxt">
<usetext source="\Table \,tabnum,\ \" placemnt="before">
<subchars>
<font inherit="1" weight="bold">
<highlt inherit="0" fontclr="blue"></subchars>
</usetext>
</charlist>
<att><fillval attname="id" fillcat="savetext" attloc="table" fillchar="conrule">
<charsubset>
<savetext textid="idtab"></charsubset>
</att>
<att><fillval attname="id" fillcat="savetext" attloc="table" fillchar="textid">
<charsubset>
<savetext conrule="tabnum">
</charsubset>
</att>
</e-i-c>
<!-- TREAT REFID -->
<e-i-c gi="obj">
<charlist inherit="1" ></charlist>
<att><fillval attname="refid" fillcat="savetext" fillchar="conrule">
<charsubset>
<font inherit="1">
<savetext textid="idstr">
<usetext source="\(\,idstr,\ ) \">
<subchars charsubsetref="stdgentext">
<font weight="medium">
<highlt scoring="1" scorespc="1">
</subchars>
</usetext>
</charsubset>
</att>
</e-i-c>
When i applic FOSI to XML file i obtain :
[A28068] Fosi compile failed using default formating information
Use show ids command to locate this error
When i choice show ids : NO errors
Thank you for Help
    Hi Bruno,
    Did you ever get this solved?
    This successfully saves the id to a savetext textid:
    <charsubset>
    </charsubset>
    </att>
    Now the stylesheet has a textid=tbl-4.
    The approach taken wants this for refid:
    <att><fillval attname="refid" fillcat="usetext" fillchar="source">
    <charsubset>
    <usetext></usetext>
    </charsubset>
    </att>
    That will give you <usetext source="tbl-4">.
    If you need to change the output to wrap the cross reference with parentheses, perhaps you can change the original savetext:
    <charsubset>
    <savetext conrule="\(\,tabnum,\)\">
    </charsubset>
    </att>
    You have to do a straight fillval into a usetext source without any alterations.
    I don't think FOSI technology allows you to fillval an id into a conrule. If you need to do something like that you have to use
    <savetext textid="idtab" conrule="#CONTENT(id)">
    I would question the need for this but I don't know your output requirements.
    Jerry Tippie
