Aug 10, 2011 10:08 PM UTC
Epic6: What controls the "completeness check," and how can I override it?
We're starting to create Schematron files to validate our XML content, now that support for them has been introduced in Arbortext Editor 6.
However, when writers on the team use the "Check Completeness" feature, they receive a list of warnings that are completely safe, in addition to legitimate Schematron issues. For example:
DITA Markup ProblemsWARNING:
"foo.xml" is missing an xml:lang attribute on the root element.
DITA Reference ProblemsWARNING:
Unusual value "new-window:PDF" specified for type attribute on xref element in "foo.xml".
WARNING: External/Peer reference to "bar.pdf" on xref element in "foo.xml" is not represented in a correct format
While Arbortext may think that every root element, for example, needs an xml:lang attribute defined, we put ours in during build time in order to support multiple languages. And new-window:PDF is also an attribute used for special purposes for the build.
Is there some way I can override or "block" checks that I know are not necessary? At the least I'm looking for just running Schematron against the file, but what would be best is Schematron + well-formedness / context rules.
    Aug 11, 2011 2:46 AM UTC
    All of the checks of DITA constraints beyond what is enforced by the
    DTD are part of the "enhanced completeness check" provided by the
    Arbortext DITA application. If you just want the regular completeness
    check, you could redefine the command alias invoked by the "Check
    Completeness" menu and toolbar button:
    alias CheckCompleteness cc -full
    -Brandon 🙂
    On Wed, Aug 10, 2011 at 6:08 PM, Garen Torikian
    > in "foo.xml".
    > rules.
    > -----End Original Message-----
    Aug 11, 2011 12:06 PM UTC
    I know that by default, Arbortext Editor won't let you use the FOSI panels to edit the "public" version of the FOSI (i.e. the one in the doctype folder with the DTD, etc.).
    You must make a "private" copy of the FOSI and edit that one using the panels.
    Can anyone point me to some documentation somewhere that describes this whole public versus private nature of Editor files? I suspect that Document Architect documentation, which I do not have, may describe this, since you can use Document Architect to edit the public Arbortext Editor files.
    Semantically, I know the difference, but does anyone know where this public vs. private concept is described in writing?
    Aug 11, 2011 12:16 PM UTC
    I got my understanding from the discussions about the "custom" folder - when it scans which in what order and which one takes precedence.
    hth,
    John
    Aug 11, 2011 1:15 PM UTC
    The "help 711" topic sort-of-kind-of-briefly touches on this (at least
    in the 5.4 Help Center).
    -Brandon 🙂
    Aug 11, 2011 5:39 PM UTC
    In Reply to Brandon Ibach:
    But how does Arbortext decide what counts as "completeness"? If the type attribute on an xref, for instance, accepts CDATA, it shouldn't matter if I put new-window:PDF or kalamazoo or what-have-you. How come the check flags it as a warning?
    -Brandon 🙂
    > in "foo.xml".
    > rules.
    Aug 11, 2011 5:44 PM UTC
    Check completness is normally checking whatever constraints the DTD/schema
    enforce. Did PTC add additional functionality for DITA and enforce some of
    the rules that are in the spec but can't be encoded in the DTD/schema?
    That would be one possiblity.
    ..dan
    > flags it as a warning?All of the checks of DITA constraints beyond what is
    > enforced by the
    > -Brandon 🙂
    >> now
    >> they
    >> element
    >> in "foo.xml".
    >> "foo.xml"
    >> for
    >> the
    >> rules.
    Aug 11, 2011 6:52 PM UTC
    Hi Ed! Thanks for asking this! I realized I need to add it to my book.
    I agree that any documentation on this would probably come with Document
    Architect, which you and I don't have.
    Here is my understanding of the situation:
    A public FOSI is the "doctype" FOSI, which is the default FOSI. A
    public/doctype FOSI has the same name as the doctype and is in the same
    directory with the DTD. For example: DocBook.dtdand DocBook.fos would be in the
    DocBook directory, along with DocBook.dcf and other doctype files.
    A private FOSI is considered a "document" FOSI. A private/document FOSI does not
    have the same name as the doctype. However, a private FOSI may have the same
    name as an.sgm or .xml file. If a FOSI is in the same directory as a document
    with the same name, that FOSI is used when the document is opened instead of the
    public/doctype FOSI. For example,user-manual.fos is used
    when user-manual.xml (in the same directory) is opened in Arbortext Editor,
    assuming they both use the same DTD. Note that if a FOSI and a document with the
    same name are not in the same directory, the public/doctype FOSI is used when
    the document is opened.
    Clear as mud? Please let me know any questions you may have.
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
    Aug 11, 2011 7:03 PM UTC
    Truth be told, I got so flustered with the FOSI panels after upgrading
    to 5.3, I pretty much abandoned them for the tagged view or a text
    editor.
    I have found an issue where if I try to copy and paste an existing
    pageset to create a new pageset, or to create a pageref, using the
    panels, I would lose one or more pagesets (meaning just the pageset
    wrapper tags with empty headers/footers). I do not dare touch the
    pagespecs with the FOSI panels anymore.
    And I never had the problem with Adept 7 thru 9, or Epic 5.0-5.1F. Just
    after we upgraded to 5.3.
    Aug 11, 2011 7:22 PM UTC
    We have not gone beyond Arbortext 5.2 yet. I have been using the FOSI panels for as long as I have been editing FOSIs. The down-side of this is that I am not intimately familiar with the OUTSPEC DTD. When I use a text editor I am never sure of where certain FOSI elements within an e-i-c can be located relative to other elements in the e-i-c and within <att> tags, etc. and what the attribute names and values are. All of this stuff is resolved for you by the panels.
    Another advantage of the panels is that you can make a FOSI change without saving the FOSI, apply the change and see the results (Print Preview is great for this.) - all without shutting down Arbortext Editor and re-launching it to apply the changes.
    Our next step is Arbortext 6.0. Maybe the panels will be problematic enough at that time so that I stop using them.
    Aug 11, 2011 7:42 PM UTC
    Jason,
    I remember that problem with the pageset style panel mangling the markup. I
    don't recall it happening recently in 5.3, but maybe like you I learned to avoid
    the problem by using the tagged editor. I'll have to check ...
    <plug>My FOSI tutorials explore the strengths of the two FOSI interfaces because
    they are best used together. For example, show ids in the tagged editor, Resolve
    in the style panels.</plug>
    Suzanne
