Excell and ACL interface
Does somebody knows how to read Excell table by ACL code? I need to read an Excell table which is looking as Illustrated Part Catalog, that is it contains rows with cells: callout_number, number_part, name_part, quantity.
Firstly task is looked simple: I saved Excell like csv file and then read lines of csv file as text file by ACL code. But some cells of origin Excell table containes few lines of text in one cell: 2 or 3 or even 4 lines of text, which have been separated by new lineseparator. In such case a string of csv file is interrupted in the separator place and it begins from new line. Structure of csv file becomes complex.
So Ibelieve it is more easy torecognize Excell.
Thanks in advance, if help is possible.
Alexander Neder
    Are you trying to maintain the information in Excel and just read it into
    the document ?
    I think what you're looking for is Data Merge.. We covered that topic in
    the Monster Garage last year:
    Three quick suggestions. The first two work for one-time (or at least
    infrequent conversions). The third option would only be useful if you were
    going to publish from the spreadsheet frequently "for the rest of time."
    1) Try saving your .csv using a different separator. My "favorite" is
    usuall the vertical bar | which on a US keyboard is shift-\ just above the
    Enter key. This should avoid the problem where the line separators are
    being interpreted as cell separators.
    2) Try copy/pasting your Excel spreadsheet directly into a table Editor.
    Search help for the topic, "Importing Excel tables".
    3) Construct a datamerge. Here you essentially pair a table format with a
    query that updates the table dynamically. The update can be on open, on
    close, on publish, and/or some combination of all three.
    The first two options should be easy to do in a short time. The third will
    take some development ... not a lot, but some.
    Finally, if this doesn't get you where you need to go, let us know and
    include what version of Editor you are working with. Some of the copy/paste
    stuff is version dependent.
    On Tue, Oct 23, 2012 at 12:07 PM, Alexander Neder <aneder@pts-russia.com>wrote:
    > text, which have been separated by new line separator. In such case a
    > So I believe it is more easy to recognize Excell.
    > Alexander Neder
    18-Opal
    October 23, 2012
    Yes, if you are planning to do this on an ongoing basis, then Data Merge
    is probably the best way to go.
    Another option, if you are good with VB or JScript, would be to access
    Excel via COM from Arbortext. You could write code in Arbortext to use
    COM to start Excel, load the spreadsheet, navigate the cells in the
    sheet, read the values, and do what you want with them in the Arbortext
    document.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Hi Alexander,
    Whoops. Sorry. It looks like I described my process for getting "stuff"
    into Excel. Excel can interpret separators other than commas, my favorite
    being the vbar. Depending on whether this is a one-time (or only a few
    times) conversion/import, it may be possible to use the strategy I've
    described, though. You would have to come up with a set of text
    find/replace (possibly using regular expressions) in a text editor to build
    the guts of your table.
    1,2,3
    For example could be turned into:
    <row><entry><para>1</para></entry><entry><para>2</para></entry><entry><para>3</para></entry></row>
    With three find/replaces.
    To build on this strategy (which I am not sure is worth your time) you
    might have to first find/replace your new line separator into some string
    you can change back later, after building the table markup.
    1
    2,3,4
    5,6
    For example might have to be first changed to:
    1NEWLINE2,3,4NEWLINE5,6
    Before being converted to a table. Once a table, you could find/replace
    NEWLINE with the newline character.
    Anyhow, sorry for the misdirect, but still possible, I think.
    > Alexander Neder
    Paul Nagai
    aneder1-VisitorAuthor
    Thanks for all who responded.
    I went by simplest way and process csv fileby acl code. (I analise all interruptions and variants in csv and acl code delivers correct table)
    Probably I will try to create rev 2 with using com object, as Clay suggested.
    Alexander
