EXTERNAL: Epic licenses
I know that if you have, for instance, a concurrent license, and you look in your Arbortext...\bin directory, there will be a DLL file named "elmdlm.dll". If you have a fixed license, there will be one named "elmdsl.dll". You can add the use of a fixed license to a PC with a concurrent license that you want to use when it is disconnected from your network where the concurrent license is managed. You would usually do this for a laptop on which you want to use Arbortext while on travel.
Conversely, you can do the opposite, so that a fixed-license-only PC can use a concurrent license on a network with a server-based license manager (although why you would want to do this if you already have a fixed license is beyond me).
Anyway, you can do this by copying the desired DLL from the Arbortext.../dll folder and pasting it into the Arbortext.../bin folder.
I believe this works for all versions of Editor up to 5.2. I am not sure about newer versions.
    ebenton1-VisitorAuthor
    Obviously, you have to have the proper license(s) available to the PC.
    Ed,
    Thanks, I've got a fixed license and I could transfer it to the PC for a bit, but I'd swear that there was another option once upon a time. I know that Adobe allows two installs for one license.
    Lynn
    Lynn,
    Rules are that your home machine is eligible if your work machine has a "fixed/locked" license, but not if the work machine is using a concurrent/portable license. I last looked this up several years ago (for version 5.1) and I don't know if the license requirements changed since.
    I believe you have to open a case to get a license for the second machine.
    -Andy
    \ / Andy Esslinger LM Aero - Tech Order Data
    _____-/\-_____ (817) 279-0442 1 Lockheed Blvd, Mail Zone 4285
    \_\/_/ (817) 777 3047 Fort Worth, TX 76108
