Feb 26, 2016 6:23 PM UTC
Extra options in New Dialog when connected to Windchill
Can someone explain why a new option appears in the New Dialog when connected to Windchill? Can it be suppressed?
The Windchill instance is SIM 10.2 M030.
Thanks.
Mar 29, 2016 6:03 PM UTC
Hi Jeff-
Are you logged on as Site administrator? SIM creates two templates at the site level. Make sure you select "Dynamic Document Templates" from the drop-drown to the right of the "Templates" label.
Feb 26, 2016 10:02 PM UTC
New dialog content is defined in the .dcf files.
Do you have a document open, when you select File > New?
If so, then you could use Help > Session > Document tab to view the .dcf file that Arbortext Editor is looking at.
If not, then you still may want to look at the current .dcf. It can be determined as stated above.
Feb 27, 2016 7:29 PM UTC
Hi Tim,
No files are open. The extra option only shows when Editor is connected to Windchill. The name of the extra option is the context that the user is signed into.
-Jeff
Mar 9, 2016 12:58 AM UTC
Do you have document type defined in your Arbortext install path
...\adapters\com.ptc.prowt.arbortext\doctypes?
Mar 24, 2016 6:59 PM UTC
Is this a template you have installed on your SIM instance?
Mar 24, 2016 8:17 PM UTC
Hi Pushpinder,
We haven't installed any templates to SIM. Our customer sees the same thing. Where can I check for templates on SIM?
-Jeff
Mar 25, 2016 2:42 PM UTC
Hi Jeff-
In SIM, open the Browser pane and select the Product. You should see "Templates" listed on the left hand side. Once you open the Templates section, see if you have one called "Tech Pubs...." and what its visibility is set to.
Pushpinder
